RCU Forums - View Single Post - OS Speed 21VZ-B V-Spec ?
Old 04-01-2008 | 09:29 AM
  #43
ezveedub's Avatar
ezveedub
Default RE: OS Speed 21VZ-B V-Spec ?
ORIGINAL: Foordy
Oh and i didnt notice a significant run time drop between pipes, the 2060 and 2035 ran almost the same within 5-10 seconds , the 2050 was about 40-45 seconds less run time than the other 2.
Keep in mind, if you need to run an EFRA or 3 chamber pipe, only the 2060 and TTR 2035 are approved. And yes, the TTR 2035 is way cheaper.
