RCU Forums - View Single Post - rustler problems
Old 04-01-2008 | 06:04 PM
nitrofan12
Default RE: rustler problems
ORIGINAL: trevord123
i always have to apply the brakes to keep it from moving. like the engine engages even at an idle.
as he has said that means that his throttle trim is to high so if you set it so it has leveled out then it should not be a problem.for the clutch it's a possibility. and for good bodies try parma they are high quality and let you paint them how you would like it to look
