RE: Is a choke required between an ESC and receiver?
Well here is some other info that will help, twist the wires from the motor to the ESC. This will cut down down on the EMI. I have done it both ways with and without. and when I have used them it is small as a pencil eraser and it is only on the signal line.. I can take a photo if needed.. almost no weight.
Scott Anderson
Team Castle Creations
Team Tanicpacks.com
K3GOL
