RCU Forums - View Single Post - Avalanche Servo Issue Noob ?
Old 04-02-2008 | 07:30 AM
vnmsgt's Avatar
vnmsgt
Default RE: Avalanche Servo Issue Noob ?
You should have gotten some silver screws with the servo that you can use to screw the steering arm on the servo arm. Also did you turn you truck on before you put the servo on the servo? You should do that because it centers the servo gear. If not the servo gear might be turned all the way to one side and not let you steer the wheels in one direction.
