RCU Forums - View Single Post - Official HPI Hellfire Thread
Old 04-02-2008 | 09:26 AM
  #1188
Buzz01's Avatar
Buzz01
Default RE: Official HPI Hellfire Thread
Hi Joe,
Nice to hear that you like the HF.
To get rid off any slop in the steering section first you have to do:
- Important!! CA between the rod end (86144) and the bal (85230), keep moving until the CA is dry! (also all other bal/rod end on the HF)
- Very Important!! There is a lot of slop on the steering Bushing (86508) and the steering arm 85507 2/4, fill that up!!!! (tighten the screw alone wil not do the job) The steering plate 87531 itself is OK
- tighten the servo saver nut (i use a high Torque Digital Servo: DS1015 from Ace r/c)
- Shim's between Front Spindle Carrier 85506 and M4 Head Screw
- Shim's behind Hex Hub Adapter 86387
This wil take most of the slop away!!
Al alu parts are from GP racing see http://www.ghhobby.com/products.php?cat=1 50% off !!!!
By the way: Don't sel, every car has some flaw !!!!!!!!!!!!!!!!!!!!!!!!! Just enjoy the ride !!!!!!!!!!!!!!!!
Roy
