RE: glow plug for thunder tiger 46
Try it and see, not much to loose. If the engines will start, idle and transition well, it's a fine plug for them. Since you've got long plugs, I'd suggest carefully turning the engine over by hand to ensure the plugs aren't so long they contact the piston, but I doubt that would be an issue. it can be for some engines from what I understand.
J
