ORIGINAL: linkadrip
Very COOL web site Thank you
Amazing videos. I can see that they can be run without the crash bars. Hope i can find some. i dont know how long to cut new ones for mine i'm sure i'll find some information on how long they should be. the ones i have are way to long.
Dont run the bike with out crash bars you will wreck it. use some piano wire 2mm thick. bar lenth make some 70mm long then put the bike on the ground and try to drive it up off the bars, depending on the grip you have determines the lenth of the bars of course you can always bend them up or down to increase and decrease lean angle to save cutting loads of bars. i not run a standered TT for a while but i think you wont 11cm from the ground to the center post holding the body on and then work from there to the condition of the track
