RE: glow plug for thunder tiger 46
Not necessary, short plugs are designed for engines smaller than .20 cu in. Any .40-size or larger glow engine will like long plugs without any concern.
Also, using an extra copper ring on your glow plug will lower your compression. This won't be desirable under normal operating conditions.
Long plugs and idle bars aren't a problem on the TT Pro .46
