Engine Problems! Please Help
Hello people,
I currently have a CY23 Engine and seem to have some troubles... The adjustment screws could be set right as well as the idle, but we have to put the idle screw in alot inorder to start it. The engine spews out alot of the oil in a brown/green color. When you start it up, the wheels start turning instantly. Air compression is working alright and the servo is fine and not putting on any throttle. Normally, unless u have the idle and adjustment screws so high, that when you put the end of the car down (while its running) the engine stops completely! Whats the problem with my engine guys? (pretty sure no air leak) Any ideas?!?!
