RCU Forums - View Single Post - Magic Hand 73" yak build thread
Thread
04-03-2008 | 03:34 AM
28
maineflyer
My Feedback: (
44
Jan 2002
758
Fort Fairfield, ME
RE: Magic Hand 73" yak build thread
plowboy1966
The Yak is a pull-pull and has exit tubes installed for the cables. There is a servo tray installed for the rudder and the elevator servos are in the tail of course and it comes with a throttle servo tray that can be mounted at the builders pleasure depending on the engine you are installing. This gives you plenty of options for a short throttle linkage. No latch, it has 2 small bolts to keep the canopy closed. It is build very light. Here are a couple of plane of the inside. Everything was lazer cut. If you are on the fence about getting the plane it is well worth the money. For under $300.00 at your door the quality is outstanding.
Reply
Like
maineflyer
View Public Profile
Send a private message to maineflyer
Find More Posts by maineflyer
View iTrader Profile
