ORIGINAL: octanehuffer
Its about time!
Use a 4 oz tank. My flight times have been around 10 min using an 11x4 prop. You MUST watch your speed! I fly at under half throttle.
My elevator is 54mm up/down and the rudder is 68mm.
My dry weight is 50.7oz. RTF weight is 54.7 oz.
The pitts muffler is lighter, so if you added tail weight it should be coming off after the pitts muffler swap.
I am using the stock wheels. The are adequate for the little bit of time on the ground, just keep the taxi speeds down and hold up 3D elevator. I didnt even fly the plane on low rates the last two times up.
Adam
I was gonna get the better servos, but they keep pushing the delivery date.. After 10 minutes, how much fuel did you have left? I think the pump draws less fuel? Using a vess 11x4 prop, love vess props and very light.
