RE: dip switch settings
i have used the manual to setup the pitch and it still wont lift off.it almost like something reversed cause at full throttle it has negitive lift and when you let off the throttle quite quick it will start to lift off...???.is there anyway that the motor qot reversed.mine spins up clock ways.also the blades are supposed to be thin side going with clock ways or thick part?cause my blades the thick part is going with the clock ways spin.
thanks for the time yadac123
