RE: Prop mounting problem
Looks like the prop is an 8-5 in the 2nd pic. We use spinner shaped prop nuts on Q500 engines without washers all the time with no problems, maybe that would be an option as someone mentioned above. That would give you another thread or two.
And finding a prop with a thinner hub would be good, too. Too bad Rev-Up is out of business, they made good props.
