RE: Hint's Tip's and How to's On Redcats
I have 15 years of porting and polishing experience. I have all the right tools and experience to do a job right and will set it up the way a person wants it. If they want all top end I can set it up, if you want bottom end I can do that as well. It is all about changing the tranfer port timing or degrees on the cylinder ports. I usually can get the best port timing from factory racing teams and what they use. I have also went thru a lot of cylinders on my own to see what was the best set-ups.
I set-up all my engines and also my friends engines as well. I have done a lot of Traxxis Revos 3.3, seems to be rc of choice here as well as Losi, I have both of them and am the only owner of a Redcat Monsoon which I am building to blow away the high dollar truggies out there, got the engine just have to dial suspension in and I think its done.
