scrap tiger well it was
Hi Guys Scrap tiger hull it has cracks everywhere so I thought why not try something this may take me a while but here goes the hull had missing lugs for suspension also cracks around the areas where the lugs had broken there are no towing lugs and also cracks in the floor of the hull lets face it its scrap so why not have a play and see what happens .Ihave decided to repair/rebuild/scratch build lets see what we can do for a small budget but lots of time.Iwill try to keep the cost to a minimum but do as much as posible so far i have spent £5 for gearboxes from FV432 which i have made into 3.5:1 ratio gearboxes will use other gears in my pnz 3 paid a total of £15 for bearings from the evil bay have enough left to do 3 more gearboxes have bought a battery 3000m/amp £12 will buy new motors speed 400 metal tracks and sprockets every thing else will come from my spares box. heres the work so far stripped the hull completely made new gearboxes which are built into the side walls changed the arms to correct postions I.e one side leading the other side trailing.it will have recoiling bb fire gun that i posted a while ago and as much metal as i can fit on it the hull and gearboxes weigh 2 1/2 llbs now and thats what i want its going to be heavy thats why it needs the low ratio high torque motors. already done some mods to the left gearbox as you can see from early photos to the last ones.next job is suspension as you can see from the photo it will be inboard torsion springs my have to mod a little but not much made them like this so i can adjust them as weight goes up.will try to make updates each week
regards pete
