RCU Forums - View Single Post - Reactor Covering ?
Old 04-03-2008 | 04:28 PM
Iflyglow's Avatar
Iflyglow
My Feedback: (79)
Default RE: Reactor Covering ?
Why do they not change the advertising so that it is acurate and not false and missleading. If the bottom of the wings are not Monokote, then you cannot say that is is professionaly covered in Monokote (This is false aand missleading advertising). The RV-4 and Rector with the problems of the covering sererating, still are not addressed. Nobody has ever mentioned problems with the little electric on this thread, or the blocked thread. They were all talking about the Gas version. You stated in the past that Monokote has never been changed. It has been or somebody is lieing, it is simple. Monokote has never done this in the past.
Look at these pic's. I have personally seen it on two RV-4's myself. You will see quite a few complaints yourself if you would actually take the time to read the RV-4 thread. The White will also seperate. Are you going to continue to say there is nothing wrong with this. The clear will lift right of the pigment. Even when you simply take the little strips of tape, to seperate the hatch from the fuse, or the ailerons and flaps from wing sections.[X(][X(]
You are simply doing the same BS beat around the bush that you did back in Oct 07.[:@]
