RCU Forums - View Single Post - Engine Kill...By choke servo or by ignition kill
Old 04-03-2008 | 08:12 PM
  #65
nonstoprc's Avatar
nonstoprc
My Feedback: (90)
Default RE: Engine Kill...By choke servo or by ignition kill
With dual battery packs and dual switches, it is quite remote for the receiver to loose power.
If the firewall is pulled out and a choke servo is installed, the choke servo push-rod actually tries to pull the choke to close. The fuel line can be pulled out as well (maybe ignite a fire when the gas touches the hot muffler).
The real danger is loose control due to receiver failure. To which, a dual receiver system is desirable and if the throttle or choke servo is separately controlled by the two receivers, killing the engine is always possible.
