RE: HELP! Homelite HBIOO 25-30cc leaf blower engine Glow conversion.
Morning AV8TOR
Thanks again. I don't know if this is a particular problem with the blower engine as it has a longer shaft then the strimmer engine. What I will do is get this engine running without the damper at full RPM and walk away. If it does shatter then I will leave the flywheel on the 30cc. Have you used the leaf blower engine without the flywheel? The other question is, I was told that the diaphram on the Zama carb melts away if you use glow fuel. Is this true?
Rich
