RCU Forums - View Single Post - Engine Kill...By choke servo or by ignition kill
Old 04-04-2008 | 11:19 AM
  #77
AirTech's Avatar
AirTech
My Feedback: (18)
Default RE: Engine Kill...By choke servo or by ignition kill
ORIGINAL: nonstoprc
A choke servo probably is a better choice, in this case.
Whit an FM or PCM receiver a choke servo will be vulnerable to RFI and may shut off your engine when you least expect it. The same is true of an Optical Kill Switch which may experience a false signal due to RFI in the receiver. At least it will not pick up any noise through the switch cable (which acts like a virtual antenna).
