RE: Realistic Propeller Thrust Calculator?
That is the program I still use to do cross checks as needed. It is not bad at all, but you cannot use it to simulate a prop running in very dense fluid like water, or at elevated field locations with thinner air, or produce power curves, or produce speed graphs, nor can you compare two engine/prop combo's with each other.
