RCU Forums - View Single Post - Pull/Pull cables in plastic tubes
Old 04-04-2008 | 08:36 PM
WacoNut's Avatar
WacoNut
Default Pull/Pull cables in plastic tubes
Hi Guys,
I am wanting to run pull/pull cables to my rudder and tail wheel. I can easily run the cables direct to the tail wheel but I wll need to modify the routing to the rudder. Can you run the Dubro 4-40 coated pull/pull cables inside plastic control rod tubing safely?? This would make life alot easier for me if this works.
Thanks!!
Anthony
