RCU Forums - View Single Post - HELP! Homelite HBIOO 25-30cc leaf blower engine Glow conversion.
Old 04-04-2008 | 11:50 PM
  #37
av8tor1977's Avatar
av8tor1977
Default RE: HELP! Homelite HBIOO 25-30cc leaf blower engine Glow conversion.
Yeah, that's not a problem. Instead of using a screw on prop adapter, make a through bolt prop adapter like you said. The prop adapter will be nothing more than a spacer, with the shaft going through it.
But the crank isn't quite as hard as you think. I have cut them off with a hacksaw without much of a fight once you break through the surface.
AV8TOR
