RE: CMP SUPER CHIPMUNK 120
Hi Tony...I will try and get some pics for you of the spots where I cut into the wing top balsa and how I covered it later today when I get home. I cut a piece of balsa out directly above the wing gear blocks from rib to rib and about 1.5" wide(big enough so I could get in there and reattach and reinforce everything. Even if your tourque blocks feel solid see if you can remove them and reattach them with epoxy. Mine were only held in place with a drop of CA. This is a "must do" repair before you fly or you will have a big repair to the wing in the near future if you don't!! To nice a bird to have it destryed because of this. I will also take some good pics of my tailwheel setup for you guys to look at and you can let me know what you think. I used standard Hitec 425BB's all around, 325BB's for throttle, flaps and steering. I use these servos on all my birds with no trouble.
Curt
