ORIGINAL: chris246810
i got new lines a new fuel filter new plugs i was going to check the one way bearing but i would have to take it off for that so i figuered while it was off mount it on a 2/4 bolt it to a work bench and then start it that way. either the the pull start or the roto starter the car is in my way.
No real reason on the OWB unless it's not working, but whatever trips your trigger. Starting it off the trk will be a hassell, fuel, exhaust, etc. Hard way to do something that's easy anyway .... your choice, not mine.
