ORIGINAL: johnnylaw
I posted this on the Exceed page as well, I have a Forza which is basically the same thing as the Tornado. I thought maybe someone over hear might have some additional ideas for me.
1. I have severe rear wheel hop when accelerating. Thought it was because of bent drive shafts, changed them , still hopping. Could it be weak shocks?
2. Is there other shocks from other brand rc's that are tougher, last longer and are compatible with the Forza or Tornado? These stock shocks seem to blow out way too quick. Any differance with the after market aluminum shocks?
3. Just put in the single speed gear box, got tired of messing with 2 speed. I noticed the single speed tranny is a little shorter than the 2 speed. The dogbone front driveshaft is too short and flys out while driving. What kind of fix is there for that? I tried moving the drive cups out a little, that worked for a while untile the grub screw came loose and the dogbone and cup went flying off the front gearbox.
4. how are you guys keeping those grub screws from coming loose. I have tried to tighten the heck out of them, then the head strips out. Tried locktite, no dice.
I love this little buggy, just need to work out the bugs. Thanks in advance.
1. could be the shocks are too loose or the foam in the tires
2. HPI nitro mt,mt2 shocks should work fine
3. the tran's should be exactly the same size, i am suprised to hear that, best thing is to put a sliver of fuel tubing in the drive cup to take up the slack, just enough so there is a little play in the drive cup.
4. i use blue loctite and make sure you have a good allen wrench set.
