As I mentioned I sought the help of an experienced modeller. He got the tail feathers on without a problem, all eyeballed, all within 1mm of true.............. not bad really.
Completed some re-inforcing on the fuse including a sidewall for the off/on/charge switch. It has yet to be fitted.
Engine mount is in, the plans show the installation of a block on the bottom of the firewall near the nose wheel steering arm, unfortunately the block is to big preventing the steering arm to go on the nose wheel spring. Damn. Dont know what they changed, it was the correct size block.
Been at it solid now for a couple of days, gonna take a breather, gather my thoughts before I continue on.
Thank you for your input.
Regards,
Dash.
