well i've got the timer set for 7 mins on my blade400 and stop after that, and the voltage on the battery is around 11 volts, i have done 7 and half and the voltage was 10.8 on my beltcp was timing myself for 10 mins or so and then i would quit. what flight time are others getting with blade400?
so with stock blade400 i plug the bind into the empty slot on tx on the left side. when i plug in the battery with the tx off it won't start trying to spin up with the esc still plugged into rx?
i wish i still had my beltcp running, but i ain't having any luck with servos in belt or blade
had servo go out on belt cp and so i bought 2 more esky servos, and installed one and was like okay i got a backup, but like 3 days later i was hovering and noticed it got really hard to control and landed, and came inside and both left and right servos had stopped working [
] i'm prob lucky i didn't crash. i couldn't afford better servos because i spent alot of money on 2 ESC on the belt because the stock went bad, and the first one i bought, i couldn't get to work so that was 50 dollars lost, so then i order a dynm esc, so that was another 20. if it wasn't for that and the servos just quitting on me, i would be doing pretty good lol. its weird though, i hadn't stripped any servos, they all have just stopped working completly[:@]
