RCU Forums - View Single Post - 2 PC sims and a USB controller for under $60
Old 04-05-2008 | 11:02 PM
flyX
Default RE: 2 PC sims and a USB controller for under $60
You just gatta dial it in.lol Just like you dial in your RC models
Download the 2.85 version of FMS this way you can run Photolistic sceneries.
The 2.85 has an option to TRUN OFF the FIXED camera view so the model won't stay stuck(FIEXED) to the center of the
screen.lol
Download the the Ratty scenery from rc-sim..becuase the instructions and the .scn file are in english.lol
Open the .scn with NOTEPAD..and check it out.
You can alter the name of the TEXTURE to just have it say down, up left, front, right, back.
Notice the instructions also say.."TURN OFF the FOG"
The instuctions would be that TEXT file that no one reads.lmao
Then go to HELI-X.net and download another FREE flight sim..now you have three flight sims for $60.
You can add CRRCsim...and have 4.lol
The text say you gatta assign idle up 1 to your keyboard in order for the engine to start in Heli-x.
anyway, you can copy and paste the scenery folder from heli-x on to your desktop or where ever you keep your files.
and you can link into a couple of more sites for photolistic sceneries in skybox formate. (the RATTY scenery is in skybox format)
There's over 70 sceneries that late time I check one of the site for Heli-x...he also make sceneries for other sims. (equirectangular)
anyway, use the Ratty .scn file as master .scn..but the toyosu scenery that I made is better, because the bottom panel gets display..if you're using vista.
The photolistics sceneries from rc-sim for FMS are kind of wack...(improper fisheyes.)
There's a crash and 3d image and text added to the .scn file.
I just remane the texture assgn name to 0,1,2,3,4,5...kind of like Prefight's skyboxes.lol
I duuno aout you all..but i have the Titan scenery in all of my sims.
You just have to makesure when you assign names of an image..you assign it exactly the same that's in the .scn file.
If it say UP ...assign UP not TOP or down as down...not bottom.
Convert all of the skybox images from .jpg into .bmp (24bit) to use in FMS.
You can leave it as .jpg for Clearview....LakeJohnson scnery for Cleavrview is also in skybox format.
Use the lake Johnson or hidden lake as a guide to set up skyboxes in Clearview.
if you're still not tired.lol...that's why you just buy sims.lol
You can use Blender (Free 3d software) to convert model from FMS , Clearview, Heli-x.
if those crazy sounds in FMS are not to your liking...I dunno...switch out the .wav files
The same for CRRCsim... you can adjust the sound frequency in whatever files CRRCsim use the .exe it's model.
In FMS it's the .par . You can use NOTEPAD to open it and adjust the model's parimeters.
or you can use the par edit addOn . It's in the programfiles/FMS folder.
You can pretty much use NOTEAD the open those perimeter files of different models for the veriouse sims.
I converted one of the heli-x sceneries back into equirectangular (360x180)...this image can be use in other sims
such as G3/4, aerofly, reflex. Or I can use it in a Virtaul cam thing of ma roo
