RE: Cleaning The Gas Tank After 4 Months Of Non Use
Ranger don't you think just emptying the tank then getting fresh nitro through it would be better. Prime it through the carb cause you know it will fire long as the glow plug is good. I'm just thinking using any alcohol or solvent may cause damage.Then use some after run.
