RCU Forums - View Single Post - Panzer III Extensive Upgrade
Old 04-06-2008 | 05:32 AM
  #47
971wright
Default RE: Panzer III Extensive Upgrade
Hi There icecreamslick ok the schurzen is orderd there is a mod you will have to do to the ariel support it needs to be lifted and fitted at an angle see photo it may be better to do it when you are fitting the schurzen see photo its from dougs build just thought i would warn you before its to late . iam trying to think infront to warn you of work that needs doing early .you will need to fit a fan towing all this weight around will make the boards pop rx14 is the best board.thats all i can think of at the moment .
regards pete
