RE: FAAST 9CAP Module vs 10C 2.4 TX
Explain something else; when you have a 9CAP Radio, you have 9 Channels; then when you put the 9C 2.4 FAAST Module you only get 8 Channels, I thought the Module only sent out the info the Radio was sending to it on 2.4 MHz or 72 MHx, depending on what Module was in use, and if the Radio had 9 Channels it should pass on the 9 Cahnnel info through the Module weather it is 72 MHz or 2.4 MHz?
