RCU Forums - View Single Post - Does all models tends to turn?
Old 04-06-2008 | 06:59 PM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default RE: Does all models tends to turn?
Are all the planes having this problem or only certain models? Which channels or control surfaces are affected? If you're using dual rates, did you calibrate at high rates? Before you calibrate, did you disable all program mixes and set all trims to neutral?
