RCU Forums - View Single Post - Fuel Supply Problems
Old 04-06-2008 | 07:57 PM
krayzc-RCU
My Feedback: (31)
Default RE: Fuel Supply Problems
r u moving in small moves i mean only a screw driver blade at a time and then retesting that is one big key to tuning a gas motor. set the H for max and then start working on the low. ONce the L is set go back and tweak the high it may need 1-3 screw driver blades at the most adjustment to achieve peak again and make sure the motor does not sag for a long run up on the grond long being about 15-30 seconds.....
