RCU Forums - View Single Post - Rust-Oleum?
Thread: Rust-Oleum?
Old 04-06-2008 | 09:04 PM
Ralph White's Avatar
Ralph White
Default RE: Rust-Oleum?
Hi Buzzardbait and 80stars.
After reading comments in various forums I was lead to believe Rust-Oleum to be fuel proof. I have just finished painting a new Aeromaster in red, white, and blue using Rust-Oleum over Worldtex covering. I was NOT planning to use clear coat over it. What do you recommend I do to correct the problems you had with Rust-Oleum? Is there a clear coat you (or anyone else) would recommend to spray over the Rust-Oleum? What colors did you have experience with? I assume you cleaned the model off after each flying session. What cleaner did you use?
Thank you,
Ralph White, Neoga, IL
