RCU Forums - View Single Post - Dihedral
Thread: Dihedral
Old 04-06-2008 | 09:10 PM
Campgems
Default RE: Dihedral
ORIGINAL: Nathan King
It's a little hard to see without a demonstration, but I'll give it a try. Imagine an airplane rolling to the left. In this configuration the right wing is producing more lift than the right since the ailerons are changing the camber of both wings differently. As you know, increasing lift always comes with a penalty in the form of increasing drag. This concept of adverse yaw is important since it is causing a right yaw (opposite the turn). This yawing increases the angle of attack on the low wing, effectively creating positive stability about the longitudinal axis. Does this make sense?
What you say is true, but that same effect would apply to a flat wing as well as one with a dhideral wouldn't it?
P.S. Campgems, are you referring to the "single" lift vector splitting into a horizontal and vertical component in a bank? Yes, the vertical component of lift decreases as bank angle is increased and this explains why elevator (to increase AOA) is needed in turns. I don't see where the components of lift and the horizon comes into play when discussing dihedral. AOA is not a measurement relative to the horizon or ground, but a measurement relative to the angle between the relative wind and the chord line of the wing.
The question was related to why dhiedral self righted a plane. AOA has nothing to do with this unless you add controls. That wasn't part of the question though as I see it.
"I don't see where the components of lift and the horizon comes into play when discussing dihedral."
See my chart and see if it doesn't make sense. Remember, we are talking about hands off self corection,
Don
