RCU Forums - View Single Post - Smoke setup without tail pipe
Old 04-07-2008 | 07:49 AM
KC36330
Default RE: Smoke setup without tail pipe
if the injector is too far into the jet blast you will burn the oil (hotter temp) rather then vaporize it and you'll have less smoke density. check that you've got the tube far enough in but not too far and that the delivery of fluid is sufficient, too little fluid will give too little smoke.
