Ringed engine question
Briggs&Stratton built a test engine that you could see through the cyl wall while the engine was running, for that purpose. the rings never stopped rotating. Although I'm sure an engine with a cyl worn oval shaped with the rings worn to it would not rotate so I guess it depends on the circumstances.
