ORIGINAL: icecube0045
Thanks a lot guys...
Is the flywheel on the bottom of the jato suppose 2 b able to move? cuz mine cant
If you cant turn it by hand that is good because that means it has a lot of comprasion, UNLESS it also dose not turn when u use the ezay start then your engine is jammed up and stuck in top dead center. You can take a flat screw driver and kinda move it but if you know nothign about this engine you should really tear it down and make sure everyhting in it is good.
