RCU Forums - View Single Post - stripped all four servos!!!
Old 04-08-2008 | 05:58 PM
theDonDon
Default RE: stripped all four servos!!!
@Bryflyguy67
I am pretty sure the servos I bought are the HXT900-(9g, 1.6Kg/cm, .12sec) found here----http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=662
I guess they are called hobbycity now. I ordered over a year ago and the servos are now $3.65 each--cool
I have found servos are a tricky thing to get right, we want fast response speed(.12sec) but the response speed is also based on the torque. If there is not enough torque the response speed is lower, the operating voltage also determines both torque and speed as well. I am still running 5v off the Align ESC but I have a 6v bec I have yet to install, in any case these cheap servos have performed as well as my expensive HS65's did at 5v. If your going to buy off-brand components make sure you always read the comments section and be aware of the bad comments-- these are usually made by real buyers and read the specs real close.
Best of luck
