RCU Forums - View Single Post - steering
Thread: steering
Old 04-08-2008 | 06:54 PM
rclynx's Avatar
rclynx
Default RE: steering
If you can find a sleeve to fit tightly over the servo saver it will work as long as the plastic can't flex..................probably shouldn't tell you this but if all else fails, put a hose clamp on the servo saver...............problem with that is you hit something hard your servo is gone........................Also you can buy a better servo saver to mount on the servo and leave a clamp on the original [&o]
