ORIGINAL: goirish
I need a starter that I can use on my Magnum 180 4s. Any one have any ideas as to the kind I should look at. I havae a hobbico and it doesn't have the horses to get the job done.
Put some after run oil into the Mag 1.80.
I'll bet it's brand new, and still a bit tight.
The standard Hobbico starter has no problems turning this engine over, provided your supply voltage is consistent.
I use a 12v 21Ah sealed battery in my flight box to power the starter, and it will turn over the Mag 1.80 just fine, it also turns over a 50CC ZDZ Gasser as well.
