RE: Showtime
hi guys' i'v got a problem and wanted to hear what you think
i'v started putting the saito 150 on the showtime and saw it wont fit in the original enigne mount (the holes of the enige mount in the firewall aren't wide enough so the enige dosent fit in the engie mount becuse the engine to wide), but if you push it into the mout with a little presure it will go in. my question is: should i drill new holes for the engine mount in the fire wall or sholud i just put the engine on the mount as it is, altought it's not a perfect fit.
also i wanted to ask what is the best prop for the saito 150- im goning to use the showtime for 3D mostly
thank
D_B
