RCU Forums - View Single Post - What kind of starter do I need
Old 04-09-2008 | 12:02 PM
opjose's Avatar
opjose
Default RE: What kind of starter do I need
If you have the starter with the black battery case hanging off the bottom, bear in mind that the battery supplies insufficient current/voltage to the starter for larger engines.
I have one of these.
I rigged it up so I could unplug the spade connectors, and use a second cord with male spade connectors hooked to the field box, to start the bigger planes.
That way I can always go right back to using the battery pack on smaller engined planes whenever I want.
