RCU Forums - View Single Post - newbie
Thread: newbie
Old 04-09-2008 | 12:03 PM
Leo L
Default RE: newbie
Hi Mike,
The Parkflyers Cessna is manufactured by ArtTech and there are two versions on the market. The original version came with a 480 brushed motor. The newer version comes with a brushless motor. Opinions on the plane are split right down the middle: half of the flyers absolutely hate it and the other half absolutely love it. However, everyone agrees that its a very fragile plane that is definitely not suited for a beginner. Also, just about everyone agrees that the supplied electronics are junk and must be replaced. The wing breaks very easily and MUST be reinforced with carbon rods and tape. The landing gear is very weak and bends at the slightest "rough" landing or if you try landing on grass.
If you are looking for a first time plane, there is nothing better on the market than the SuperCub. Get the SC, learn to flyit, then a wide world of "second" planes will open up to you. If for some reason you don't want to get the SC, check out the Multiplex EasyStar. It's nearly as good for a beginner as the SC. The major drawback is that it has no landing gear.
