RCU Forums - View Single Post - what could cause this?
Old 04-09-2008 | 01:20 PM
Rodney
Default RE: what could cause this?
This is where a Voltwatch would be very convenient. I suspect that you have either a bad switch, marginal wiring (corroded connections) or battery going bad (not holding a charge or high internal impedance. By installing a Voltwatch or equivalent and checking before and after each flight while cycling the sticks, such problems will become quite evident.
