See here:
Falkon Website:
It has a nice flash anim (but poor english)
It does sound like the low end and high end may be too rich...
Also when you get CLOSE.... move the needles just a couple hairs...
Originally posted by jmiracle
OK, here's the latest...
I haven't yet reset the timing to 7mm. I will do this later tonight.
I set both needles to one turn out....this seemed to help.
I can now get consistent starts, HOWEVER....
It only runs at idle....it sputters and quits with even a few clicks of throttle. If I don't touch the throttle, it will just sit there and run.
I thought this seemed like it might be lean on the low end, so I gradually richened things up to 2 turns. It only seemed to make it worse.
I was going to back it off to .75 turns, but then it started acting like it was flooded, so I've quit for now. Probably won't be able to get to it again until tomorrow.
Any thoughts?
