RE: What kind of starter do I need
You can rig your present starter to stay the way it is for most engines and then improvise a quick connect set-up so you can plug your fieldbox battery in parallel with it for the biggies. I wouldn't leave it connected when not in use though, the big battery may try to charge the little battery.
