RE: Moki 1.8 performance
""Mejzlic 19X8 propeller. Spins at a solid 7700 RPM
""0% Nitro 22% oil, consisting of 75% Klotz synthetic/25% SIG Castor - Bisson Pitts - both pipes fully open, Peak Readings - TNC Tach 19x8 MenzS - 8800 rpm ""
""FAI fuel (80% meth + 20% BeNol) spinning a Bolly 19x8 CF prop delivers a solid 8100rpm and peaked to 8400-8500 rpm on the bench after 2Lt break-in""
""1450 and the top end was 7150 with a Xoar 19x8 prop""
""straight fuel, oil edl 18%, Zinger 20 x 8, 7600 rpm""
HEY,, these are really impressive numbers !! you guys have got me thinking about the Moki 2.10,, see I need to turn a 3W 20x8 at 7200 in flight or I will not be happy, the 3W props load an engine much more than a Zinger of the same size,
do you guys know of any Moki 2.10 numbers ???
Jim
