RE: H9 60 Size P-47 Thunderbolt-Build & Flying
What did you guys do with the firewall who are running the G20 gasser? I just noticed while looking at mine that it has the + shape reinforcement to it for the slanted motor mount. Also, I was talking to a guy at the local air field last weekend and he put the G20 in his and recommended puting tail braces on it as he has alot of flutter with his due to the speed the G20 provided. Have any of you had any issues with this? He was running a 2 blade prop on it. Sorry, im not sure what size. Would a 3 blade slow it up a bit to prevent the possible tail flutter?? If so, what size 3 blade works well with the G20?? I would like it to look somewhat scale with a 3 blade prop.. I run at about 4500 ft above sea level, so I will lose some power with it im sure. This will be my 2nd RTF, so im still fairly new to all the tricks you veterans have up your sleeves. Any input will be appreciated.
