RCU Forums - View Single Post - power supply question
Old 04-10-2008 | 10:50 AM
cloud-9
Default RE: power supply question
ORIGINAL: xsnrg
Yes that makes sense to me.I guess my problem was that I thought the volts had to be at or above what the battery was rated at....so,something with 30A and min of 12vdc would do....take a look at these specs and tell me if you think this would be ok for the:
Features:
Perfect for Home, Shop and Hobbyist
Built-in Cooling Fan
Input: 115V AC, 60Hz, 500 Watts
Output: 6~15V DC(Adjustable)
22 AMP Constant/25 AMP Surge
Powers 6~15V DC Devices such as Cellular Phones, CB Radios, Scanners, HAM Radios, Autosound Systems, etc.
Screw Terminal Connectors
Crowbar Over Voltage Protection
Short Circuit & Thermal Protection
Fuse Protected
LED Condition Indicators
3 Prong Grounded AC Plug
Heavy Duty Cabinet & Heatsink with Anti-Skid Rubber Feet
Electronic Overload Protection w/Auto Reset
Dimensions: 11.81''L x 9.05''W x 7.08''H
1 Year Manufacturer Warranty
No, that only does 330 watts. You need 360, plus you should calculate at 80 of rated requirement. So I would make sure amps X volts = 400 or more. Check out Mastech and Tekpower at radios4you.com.
Also, if you download the manual and read it you'll see the DUO needs 15v do work to its max.
Jim
